Cheat Sheet or Saved System Settings
Using different settings and configurations for different metals and job tasks we find ourselves making adjustments perhaps too often. Do you use a printed cheatsheet to keep track of settings, memorize them, or use your laser welders built in memory slots to keep track of settings?
RE: Cheat Sheet or Saved System Settings
To answer your question, depends on the laser. Older models I rarely worry about the setting and more on the voltage and beam size. You Memorize over time exactly what MM size and voltage to use as you get more and more used to the machine. Newer models you definitely can use the programed settings and fire right away. They also let you store your own setting like the ones I have memorized for certain tasks.Javier Odom wrote: ↑Mon Oct 02, 2023 11:10 am Using different settings and configurations for different metals and job tasks we find ourselves making adjustments perhaps too often. Do you use a printed cheatsheet to keep track of settings, memorize them, or use your laser welders built in memory slots to keep track of settings?
Yeah, we end up having most things memorized, however, for those odd jobs that we do not do as frequently we find ourselves either quickly looking it up on a cheatsheet or we refigure it out. Our machine is on the older side, but it does have some memory slots. I believe the newer laser welder we are looking at has stored settings.Bemamali wrote: ↑Wed Dec 20, 2023 5:42 pm To answer your question, depends on the laser. Older models I rarely worry about the setting and more on the voltage and beam size. You Memorize over time exactly what MM size and voltage to use as you get more and more used to the machine. Newer models you definitely can use the programed settings and fire right away. They also let you store your own setting like the ones I have memorized for certain tasks.
