xTool F1 Ultra Laser Engraving Brass Plate for Hand Engraving Template
Discussion about the xTool F1 and F1 Ultra
This is for the xTool F1 Ultra.
The following settings are for a 1.3mm brass plate, using an SVG image file. Once this has been laser engraved the engraved/etched template can be used to hand engrave the plate.
  • Fiber IR
  • Power: 55%
  • Speed 3,750 mm/s
  • 1 Pass
  • 300 lines/cm
  • Bi-Directional
  • 30 kHz
These settings could be tweaked to provide a lighter and cleaner template.
Return to “xTool F1 Series”
