Calibrating Thunk3D Jewelry Scanner
Discussions regarding Thunk3D scanners.
Using the Jewel3D v2.0 software, calibration is fairly simple.
  1. Open the Jewel3D software
  2. From the top right menu options, click the Calibrate button.
  3. Select the calibration mount plate that you have. I have the CB-5mm. The other option is the CB-10mm.
  4. Click the Confirm button.
  5. Place the calibration mount plate on the machine.
  6. Lower the vertical and horizontal settings to their lowest setting, in the bottom left of the screen.
  7. Click the Calibrate button.
  8. Click the Confirm button to exit the calibration.
When the calibration is completed a notification will appear at the top center of the screen. It will be similar to the following:
Result accuracy as 0.0031mm Extreme Value 106
Some additional considerations.
  • Be sure your calibration mount plate is clean.
  • When you remove the mount plates, do not shift the rotating arm.
Return to “Thunk3D”
