Matrix 9 Menu Bar Unresponsive - Windows 11
We have been using Matrix for years, with the regular set of issues. Today, a new issue was introduced to us. This new issue is that Matrix started up, but once it was open the menu buttons are unresponsive. Specifically, the menu bar at the top of the program window does not respond, it is as though the menu is frozen.
Re: Matrix 9 Menu Bar Unresponsive - Windows 11
So we have a fix!
The fix was taken from Gil Remillong's post.
To fix the Matrix 9 Menu Bar being unresponsive, create three new Windows Firewall rules. I am going to go through the entire process here:
When you are done with the above you will have three new local firewall rules that are blocking the three primary applications that reach out to wherever they reach out and cause issues.
Now you can start Matrix and be patient. It may take a little longer to run, but just let it do its thing. The Matrix menus will be fully operational, as they should be.
As to why this is happening, I am guessing Stuller/Gemvision changed something on their end which is causing issues.
- Open Windows Settings
- Select Network & internet
- Click Advanced network settings
- Select Windows Firewall, which should open a new window
- Select Advanced settings; you may have to authenticate as an Administrator for the computer/domain
- Select Outbound Rules
- 01 Select New Rule
- Select Program, then click the Next> button
- Browse to the program’s path ("C:\Program Files (x86)\Matrix90\") (If you get a warning when you click "browse" just click OK to close the warning.)
- Select the Matrix90.exe program ("C:\Program Files (x86)\Matrix90\Matrix90.exe"), then click the Open button
- Click the Next button
- Select Block the connection, then click the Next> button
- Select all three choices, then click the Next> button
- Enter the program’s name and optionally a description
- Name: Block Matrix90.exe
- Click Finish
- 02 Select New Rule
- Select the MatrixStartup.exe program ("C:\Program Files (x86)\Matrix90\MatrixStartup.exe"), then click the Open button
- Name: Block MatrixStartup.exe
- Click Finish
- 03 Select New Rule
- Select the MatrixUpdater.exe program ("C:\Program Files (x86)\Matrix90\MatrixUpdater.exe"), then click the Open button
- Name: Block MatrixUpdater.exe
- Click Finish
This saved my life!!!!
Thank you!
Thank you!
This saved me a few days ago as well. I had forgotten about it but one of our Jewelers reminded me about this post. I went through the instructions and the software started operating as it should.
