Raymond Weil Freelancer 2760 st1 gva01
RE: Raymond Weil Freelancer 2760 st1 gva01
This is a Freelancer Diver Geneva Limited Edition Mens Steel Blue dial 42.5mm, Stainless Steel Bracelet, Gradient Blue Dial, Black Ceramic Bezel watch.
Limited Edition: 310 units
"This limited edition is a true ode to Geneva, the city where RAYMOND WEIL started and continues to operate. In this timepiece, you will find many nods to the Leman Lake: a gradient blue dial, 310m of water resistance which is the maximum depth of the lake and an engraved case back with the Jet d’Eau. It is an elevation of our freelancer diver collection, resonating with the depth of the Leman Lake." - ELIE BERNHEIM, CEO, RAYMOND WEIL
Originally: 2,295 CHF
Description
The freelancer diver Geneva Limited Edition pays tribute to the place where RAYMOND WEIL was founded and continues to call home.
At the heart of the new freelancer diver watch sits the Calibre RW4200, an automatic movement with a power reserve of 38 hours. The 42.5mm stainless steel case features a scratch-resistant unidirectional rotating bezel in black ceramic with light grey graduation and a luminescent indicator, as well as a screwed-down crown embossed with the Brand’s signature RW monogram.
This timepiece is water resistant to 310m which is the depth of the Lac Léman. This number has also been defined to limit the production of this special edition.
Endowed with a blue gradient dial, the model pays tribute to Lac Léman. The drop-shaped aperture positioned at 6 o’clock reveals the date and the design of each numeral on the date disc has been optimally shaped to improve legibility. The barrel-shaped hour and minute hands converse with applied indexes, all treated with Super-LumiNova®.
Equipped with a screwed-down case-back, the rear of the watch is engraved with a depiction of the “Jet d’Eau”, the famous Genevan landmark. The folding clasp of the stainless steel bracelet has a double push-security system and integrated steel diver extension allows for easy adjustment of the strap width.
Technical data
Reference: 2760-ST1-GVA01
Collection: Freelancer
Shape: round
Movement: mechanical self-winding movement – RW4200
Power reserve: 38 hours
Movement caliber height: 4.6 mm
Case material: stainless steel with black ceramic bezel
Case size: 42.5 mm
Case thickness: 11.8 mm
Case back: screwed-down with special engraving
Water resistance: 310 m, 1017 ft, 31 atm
Crystal: sapphire crystal with dual-sided antiglare treatment
Dial: gradient blue, applied indexes enhanced with light grey Super-Luminova®
Date window: at 6 o'clock
Crown: screwed-down and fluted with RW monogram
Bracelet/Strap: stainless steel
Clasp: Diving stainless steel folding clasp with double push-security system and extension system
[video=youtube]https://youtu.be/eZtzILEQ8R8?feature=shared[/video]
Description
Technical data
Shape: round
Case size: 42.5 mm
