Flashforge WaxJet 400 Wax 3D Printer
This is an unofficial Flashforge forum.
All of this information is taken from their website at the following link:
https://www.flashforge.com/product-deta ... 3d-printer
If you would like to comment on the accuracy of this, and/or your personal experiences with this device please feel free to do so.
WaxJet 400, a large-size, high-precision, multi-jet wax 3D printer, can print casting wax patterns with smooth surface and high fineness. It is suitable for investment casting fields such as jewelry, crafts, precision casting and aerospace.
Application Scenarios:
Jewelry Industry
Digital mass production workshop solution for jewelry
Dental Industry
Digital solution for complete dentures
Precision Casting Industry
Digital casting solution
Art Foundry Industry
Parameter Specification
1600mm height
775mm depth
1352mm width
Product Specification
[table=product_specification]
[tr][td]Printing Technology[/td][td]MultiJet Printing (MJP)[/td][/tr]
[tr][td]Build Volume[/td][td]289*218*150mm[/td][/tr]
[tr][td]Printing Mode[/td][td]XHD: 1200*1200*1600dpi, Layer thickness: 16um[/td][/tr]
[tr][td]Dimensional Accuracy[/td][td]±0.04mm/20mm[/td][/tr]
[tr][td]Power Supply[/td][td]AC220-240V, 50Hz, 4KW[/td][/tr]
[tr][td]Equipment Dimensions[/td][td]1352*775*1600mm[/td][/tr]
[tr][td]Net Weight[/td][td]480kg[/td][/tr]
[tr][td]Gross Weight[/td][td]630kg[/td][/tr]
[tr][td]Package Size[/td][td]1530*900*1837mm[/td][/tr]
[/table]
Software & Connectivity
[table=software_connectivity]
[tr][td]Slicing Software[/td][td]WaxJetPrint[/td][/tr]
[tr][td]Supported File Format[/td][td].stl/.slc[/td][/tr]
[tr][td]Email Notification[/td][td]✔[/td][/tr]
[tr][td]Hard Disk Capacity[/td][td]500G[/td][/tr]
[tr][td]Connectivity[/td][td]Network 10/100/1000, Ethernet/USB[/td][/tr]
[tr][td]Supported Operating System[/td][td]Windows 7 / Windows 10 (64bit)[/td][/tr]
[tr][td]Working Environment[/td][td]Temperature: 18-28℃, Humidity: 30-70%[/td][/tr]
[/table]
Material Specification
[table=material_specification]
[tr][th]Material Name:[/th][th]FFWJ1100[/th][th]FFWJ1200[/th][th]FFMS3100[/th][/tr]
[tr][td]Material Type[/td][td]Part material[/td][td]Part material[/td][td]Support material[/td][/tr]
[tr][td]Net Weight[/td][td]3.0kg/bottle[/td][td]3.0kg/bottle[/td][td]3.6kg/bottle[/td][/tr]
[tr][td]Composition[/td][td]100% Wax[/td][td]100% Wax[/td][td]Wax support material[/td][/tr]
[tr][td]Color[/td][td]Purple[/td][td]Pink[/td][td]White[/td][/tr]
[tr][td]Density@95℃(liquid)[/td][td]0.76g/cm³[/td][td]0.85g/cm³[/td][td]0.85g/cm³[/td][/tr]
[tr][td]Melting Point[/td][td]68°C[/td][td]80°C[/td][td]55°C[/td][/tr]
[tr][td]Softening Point[/td][td]63°C[/td][td]70°C[/td][td]-[/td][/tr]
[tr][td]Volumetric Shrinkage①[/td][td]1.10%[/td][td]0.90%[/td][td]-[/td][/tr]
[tr][td]Linear Shrinkage[/td][td]0.70%[/td][td]0.70%[/td][td]-[/td][/tr]
[tr][td]Needle Penetration Hardness②[/td][td]9[/td][td]7[/td][td]-[/td][/tr]
[tr][td]Ash Content③[/td][td]<0.01%[/td][td]<0.01%[/td][td]-[/td][/tr]
[tr][td]Description[/td][td]High-precision casting wax material[/td][td]High-precision dental casting wax material[/td][td]Hands-free dissolvable support material[/td][/tr]
[/table]
① Volumetric Shrinkage SH/T 0588-1994
② Needle Penetration Hardness GB/T 4985-2010
③ Ash Content GB/T 14235.3-1993
Core Functions
One-button Automatic Printing
Import the model data via WaxJetprint. Find the file data in the print queue and click the “Print” button. The system will automatically complete printing the model.
Automatic Reloading & Material Run-out Reminder
2*2 material cartridge configuration; When one bottle of material is used up, it will automatically switch to another bottle.
Maintenance Plan
The maintenance plan is pre-installed in the equipment. According to the hours of use of spare parts, it will prompt the user to maintain the equipment in order to keep the equipment in good running condition.
3D Automatic Layout
Import in batch, customize the attributes, and select the area and height for automatic placement. The automatic 3D placement function selects the optimal solution through preset iteration times.
Return to “Flashforge”
